Ferguson Rotary Hoe
Travis13000
I just got one of these yesterday and Im trying to find out any info possible. After reading comments from an old post on here, Ive discovered that its not an areator ( which is what I thought it was) and it was used to bust top soil? This implement splits in the middle amd seems to be held together as one peice by two peices of metal which are bent. I have absolutely no use for this, but I love older equipment and implements. Just wondering if I should fix it and try to trade it or did I just get a free yard ornament. Thank you in advance.
It is a rotary hoe used primarily behind the MH50.
It doesn't have a designation I can find , this is unusual as almost every implement is well documented .
Described as a high speed implement for weeding and breaking up ground crust. The two halves are supposed to be able to move independently, perhaps the bent metal in between isn't original .
That was probably a somewhat rare implement even when it was new. Definitely a keeper. They were also sold as Dearborn and some others as well. The one I had had square corners on the weight boxes and no lift hitch. The old fellow selling it thought it was sold as a Brady. My Ford dealer got OEM bearings but that was 25 years ago.
The parts book says if you would like to use it as an aerator you can change the hitch to the back from the front and it will work for you
Got one of those buried under my scrap pile. I've seen the tines taken off and painted with sunburst yellow and orange colors.
my dad had one just like it back in the 50's. if you use it wear a hard hat. it liked to throw rocks/stones. pulled with to20 and to35.
