ferguson with a v8
Did Ferguson put a v8 in any models like Ford
had the funk v8. If so how rare ate they. I
believe this tractor is a to 20 going to go look at
it Saturday thanks for any information on this
paul
There were a lot of Fords that individuals changed over to larger engines. I have seen several Fergusons also but neither came from the factory that way, I do not think. If you go to "you tube" and type in Ferguson V8 tractors or something similar I believe you will find quite a few of them.
I could be corrected but I don't believe Ford did the Funk.I think it was a kit sold so a person could convert the Ford to a 6 or an 8 cylinder. I hauled a Funk with a flat head 6 to a guy in Oklahoma years ago when I wad doing hot shot (did mostly antique equipment) kinda cute. Bought a pretty dollar.
look over at the MF forum someone with a little bit of money got creative and made the Massey Assassin don't think it's good for plowing though.
Saw this one at a show a couple years ago.
Dan
dan,that v8 ferg is a te20 with a chevy 350.gent lives 2 roads over.and yes it was at the pageant of steam in Hopewell n.y.they have used it couple times to skid logs!
I understand that the early small block Fords ( 221 , and 289 ) with a 5 bolt bell housing pattern bolt up quite easy . You have to do some frame work to keep the front end attached .
This from the archives and he still posts on the Case David Brown forum:
From the archives posted by DKase in 2002
DKase
Re: Z129 is Shot, Need Suggestions in reply to Chuck (CA), 04-12-2002 11:04:48 289 Ford V8 five bolt bellhousing will fit with some work. Did it to mine 8 years ago runs GREAT!!!!!
DKase
04-16-2002 06:35:46
204.221.160.93
Re: Re: Re: Z129 is Shot, Need Suggestions in reply to PAUL, 04-16-2002 01:40:10 It has to be a 221, 260, or 5 bolt bellhousing 289 ford engine. The 289's 65 and newer have a 6 bolt housing and that won't work. The biggest problem I had was cooling. Mine has a belly mower under it and it is a daily user. I ended up with the hood, grill, and radiator from a 930 Case diesel before my temperature problems were completly solved. I don't have a digital camera so a picture is tough. It fits in there so nice that most people don't even notice it. Takes 2 hours and less gas to mow my 7 acre lawn than the Z120 did. To explain how I fit it in would take me an hour and several pages. I'm calving now and can't take that kind of time, but I can sure answer questions between calves. I live in SD and you're welcome to come and look. I havn't had time to paint it up so it is not real pretty,but it has potential to be a showstopper!
(quoted from post at 22:10:22 04/01/14) Did Ferguson put a v8 in any models like Ford
paul
Paul,
How did the V8 Fergie look? I would like to find one some day.
