caterpillar guy
Sounds like if you had an old NI baler in the 5w6h you would be in tall cotton. They are a fixed chamber baler with an open throat .they will swallow about all you can get in them. Once the roll is started you can't plug them hardly. IF hay gets to dry it will have a problem with feeding when full so just get the twine to wrap and dump it. It will bale anything you want to put in it. It has a big open cavity in there to let hay tumble at first then fills up as the hay goes in. I've not had much trouble with our big baler. The small one was a poor design for dumping the bale the door hinge is to far back so the bale can set in there and roll till the cows come home. I have hay windrows as big as I can get over with the tractor ands the big one will just swallow it. The pickup is your speed limiter on it. Not saying they are the be al end al of baling just it will feed in better than you describe of that one. They also have endless belts so no splices to contend with.
