Firing problems
I bought a 2n last week and now I can not get it to fire. I was driving it through the yard when it ran out of gas and I didn't turn off the key and it ran my battery down overnight. I have put gas in it and tried starting it up and it will not. I filed the points and still no fire to the plugs. I replaced the points and still no fire. I get a weak fire between the points when I spin it over. By the way it is a front mount distributior. When changing the points I noticed that it does not have a condenser. Is this common for them not to have condensers. Any suggestions? Jack
Jack.......it is to your best interest to squander $25 (cheap) for the 156pg I&T FO-4 manual. It will show you how to set yer points. And YES it MUST have a condenser. While filing yer points will gittcha going outt'inna field, they don't last very long 'cuz you remove the HARD facing of the points.
You do know ittza 2-bolt, 15-min job to remove yer distributor and change the points (gap = 0.015") on the kitchen table, don't you??? Since you didn't turn yer ignition key OFF, you probably KILLED yer squarecan ignition coil. Ittza $40 lesson learned. And you probably KILLED yer weaksister ignition switch. $15 (cheap lesson learned)
And ALWAYS TURN yer under the tank glass valve OFF or you will HYDRAULIC LOCK yer engine and bend piston rods, not good. .......Dell, yer self-appointed sparkie-meister
I don't think you comment is necessary. For your information I do not drink. If this is the only thing you have to offer then just shut up. Thanks, Jack
I think you'd better take dell up on the advice to buy a manual...you may need it later on when no one responds to your posts because you are telling members here to shut up.. which will likely get you -0- help in the future.
and yes.. you have to have a condensor.. and yes.. you may have thermally damaged your coil by leaving the key on.
soundguy
Hey dumb a$$ why waste time and space - Try pulling some stumps with your top link. Have you ever contributed any useful information - I doubt it.
