I have a 1939 Farmall H. It runs fine but the charging system has never worked properly. Before I retired I had a professional come out and "fix" the charging system. Keep in mind this was before I understood the inner workings of the 6V positive ground system.
When he was done I had a rebuilt 6V generator and he replaced the cutout switch with a VR. It never dawned on me to have him show me 1) the ammeter readout showing charging, or 2) to put a volt meter on the battery to show me 7.2 volts while the tractor was running.
Now that I am retired I have time to dig into the charging system and find out why it's not charging. I've used most of this forum to gather testing techniques and trouble shoot my charging system. I am the point of conducting the motor test to see if the generator is working. I took the generator apart per forum instructions.
What I found was that the inners looked new with the exception that the commutator bars were tarnished. I buffed them carefully and put the generator together.
I should note at this point that my 3 brush wiring looks different that the diagrams I have found on this site. My field wires go from the F terminal and end at one of the main brushes, not the third brush. And then A terminal goes to the third brush.
When I conducted the motor test. I attached the pos battery to the generator case, grounding the F terminal to the generator case. Then I connected the neg side of the battery to the A terminal and the generator spun. Then I disconnected the grounded F terminal expecting the generator to speed up, but instead it stopped and reversed direction.
This is where I need help.
Thanks,
WRG
Thanks,
WRG
