Float decking lumber
Anonymous-0
I am redoing my ten ton tri axle float. Well in the midst of it. I recently installed brand new axles, suspension, rims, rubber, brakes, etc. (basically everything under the deck is new) and I installed a heavier pintle hitch eye.
Now I am installing the deck lumber back on ( I had to install diamond plate over the new wheels as there bigger so I had to notch out my existing decking to accomodate the new diamond plater over the wheels) and I'm looking at it thinking maybe I should install a pressure treated deck?
The decking lumber I have now is absolutely fine ( 2" oak ) but I do prefer the look of the finished lumber (my lumber is rough).
My question is my crossmembers that support the decking are 24" on center and I want to know if it is safe to install dressed lumber dimensions on that span? I see all the new trailers are 16" centers for their crossmembers and they have dressed pressure treated lumber as decking material.
I know oak is way better but while trailer is naked I do have options at this point.
Please chime in!
Thanks,
Tom
Case450,
Personally, I wouldn't chance it. I can't speak directly for trailers but I have got my Ford 755 TLB (19000#) unstuck in the past where I've raised it up out of the mud using the stabilizers and laid 2x10s pressure treated lengtthwise underneath the rear wheels to "walk it out". I would fill the "hole" with firewood and then lay the planks on top. I remember once I tried to cheat and not support the plank completely, leaving a couple of feet unsupported between the last firewood pieces and the edge of the hole. Snapped the 2x10 in two. Can't say exactly what the span was, but if I were you, I'd stick with the 2" oak.
Sounds like you got a like new trailer and unless the oak was really busted up, I'd reuse it. Even then, I'd probably go to the sawmill to get any replacements pieces.
2" thick decking as compared to 1.5" decking of the same species is 78% stronger for bending moment and 33% stronger for shear---the working stress allowable for the species your using will also figure in--i would say the oak is by far superior to pressure treated S4S pine and if you have a track machine the spacing of the supports are not that critacle as compared to a wheeled machine.
