Flooding Engine again?
I have decided that it is the ignition because it did the same thing again today. Apparently it does not have a module like the old Fords had but has a coil needing replacement. Is the coil the most likely problem?
To save us from looking back 8 or 10 pages, want to give us a CLUE as to what you are working with?
We used to have that problem with a 92 chevy 454. We'd unplug the fuel pump and crank her until she started. The tranny went out snd she was parked before we found the problem, but the computer had been messed up by a guy who tried charging the battery with a welder. Jim
We have replaced alot of coils on these causing hard or no start problems . You may also want to check your fuel pressure . Fuel pump may be weak .Will cause hard start ,no start .
