fluid dampner for a 301 IH
I don't know if this will help, but from the factory a lot of IH trucks with the IH-built straight six only came with a crank pulley, and no balancer/dampener. Seems these engines are fairly well balanced to begin with.
With a bunch of aftermarket parts, you might have to go to the expense of having the reciprocating assembly balanced.
We use one from ATI on our 560 (5-6000 RPM). We made our own hub that adapts it to the crank. Have your crank nose checked before making the hub. Our first one was egg shapped .0015 (crank) and we ended up having to make a new hub after we trued up the crank. Use a real light press fit .0005-.0015. Don't use junk seel either, use 4140 or better. I am pretty sure we used 4320.
The ATI dampers have 1 hole off of the regular bolt hole circle, so ask them for a layout of the bolt holes (IE 6 holes are normally 60 degrees apart except 1 is 55 or something)!!!
You can send the ATI dampener back and have it rebuilt if you need to (elastomer??).
I agree with papuller. I "Mickey-Moused" one on my 301 and it came off......scary. Find a good machine shop. and do it right with a hub.
The Fluid damper is really used for ridding bad vibes not to balance a motor. My rotating assembly is balanced but just wanting to put a good damper on it. Someone had just told me that there is an oldsmobile damper that would fit. Anybody heard of this?
