Fluid film question
andyin ct
I have a truck with some surface rust on the frame. Anyone ever use Fluid Film as a rust preventer on a truck. If I scrape/wirebrush it and pressure wash it and apply the Fluid Film would it help or is there another product?
I use it on my truck frame and under body bout every 6 months. There is always still a film on there when re-applying so I feel it is working. been doing it for three years now so not much long term info yet.
I tried it several years ago.. 40 + dollars a gallon.. It didn't seem to leave anything that looked like a protective coating on my trucks.. I've since been using boiled linseed oil and used atf in a 50/50 mix and spray it on.. Once a year just before winter, I'll wash down the underside of the trucks , then coat 'em good.. This mixture oozes out of the cracks and crevasses for months..
I got the frame pretty clean - Probably rustoleum primer and top coat it with an enamel - Then maybe before winter hit it with fluid film if I decide to spend the money or try the linseed oil and atf or bar and chain oil.
