Ford 1710 starting problem
Anonymous-0
I have a Ford 1710 that broke a fuel line and all the diesel drained out. Now it won't start. It turns over fast but won't fire. Do I need to bleed the injectors and if so, how do I do this.
Any suggestions would be greatly appreciated.
You should have bleed screws at the filter and injection pump bleed the air there first, then you also may need to loosen the lines at each injector and crank until fuel comes out.
