I was bushhogging for a few hours and the temp started climbing. I always keep an eye out for leaks or steam since it overheated from a clogged screen when I first got it...I didn't know that was a thing you had to watch for...I noticed the lower radiator hose was collapsed. When I stopped I saw that the over flow hose had some dripping out and that seemed to be the only steam happening. The lower hose is soft....so squishy. The upper is old but not as bad. I did some googling and saw that some people put a spring inside the house to keep it open. So I thought my problem was the lower hose was old. I did this. When I drained some coolant out to replace the hose it was brown/rusty colored. I didn't have the coolant to flush the radiator and add new so I poured the old back in, finished the job and brought it in. I know I need new hoses and to flush the radiator...overhaul the cooling system...but I can't find what type of coolant to use and should I use a cleaner in the radiator first or just remove and run water through upside down? Any of suggestions for this task would be appreciated. Trying to avoid spending 500 on a new rad if this will fix the problem. Its a diesel if that matters to the coolant.
