xsidewinder
I just completed another compression test, with engine warm and throttle open 100% the cylinders were all 90 psi. The engine runs pretty good except for some black smoke and pops a little like the valves need grinding. I think the carb is the wrong one for this tractor because the tag shows E3NN AC .....13871D....12 85. I think this is from a 1980's tractor a 1960's letter should start with a C? Do you think this carb will work with some adjustment/jets changed? I included a picture of the carb on my last post. As far as the compression ...leave it alone...put a solvent/penetrating oil in the cylinders and hope its just sticky rings? thanks again for oyur help Rick
