Ford 2000 radiator problems
Anonymous-0
Sirs
I installed a new radiator on my ford 2000 3 cylinder diesel tractor. I have a problem, I loose all the water out of the radiator overflow outlet which is located under the radiator cap. It looses the water wheather it is hot or cold. The water evacuates in about a 1 hours run time. When I fill the radiator to the top and run the tractor with the radiator cap off it appears that the water pump is pushing the water out of the radiator. This is when the tractor is cold. The tractor doesnt seem to have a thermostat on the outlet of the tractors cylinder head. Is it suppose to have one?
Any ideas about this would be helpful.
Thanks
Jack Rhoades
I'm not familiar with your system, but some general questions come to mind:
Was it OE replacement rad?
Did you compare them (new with old) to see if cooling tubes seemed to be same size, number??
Did you block lower outlet, fill with water, open lower outlet to make sure water going thru new radiator fast enough??
If new radiator capacity lower or partly plugged, could be water pump pushing in more water than can run thru, forcing some out overflow.
(Not missing any workrags, by any chance??). Good luck.
