down_right
so my idiot father insisted on driving our ford 3000 over some very steep and narrow furrow ditches while spraying with a completely full 110 gallon sprayer the other day, LOTS of hard bumping, up and down, up and down. afterwards (literally like 200 ft), the light which i believe is the check oil light came on (oil level was fine) and an odd clanking sound was heard. the tractor will not turn on now, it makes a sound exactly like in this video. it ap[pears that owner ended up having a seized engine from breaking the oil pump, and i fear that this has also possibly happened in my tractor.
i have charged/swapped batteries, attempted to jump battery, bypass solenoid, etc. and nothing works.
what else can i try to troubleshoot the problem, and is there any likelyhood if the engine is seized if it can be 'fixed', given how it wasn't driven more than a couple minutes after the clanking noise began/light turned on? i read on some post about trying to start the tractor with the clutch depressed, unsure if that is worth trying, or if every attempt to turn it over creates worse damage
thanks
thanks
