Copy that. I will try. I think I ran the starter for maybe only 10 seconds at a time.Best have ALL injector lines loose at the injectors for bleeding, NOT one at a time. Also crank engine for 30 seconds at a time, then stop for a bit for starter to cool. Most rotary pumps won't bleed well to injectors with only 5/6 seconds crank time.
If that doesn’t do it, would you recommend taking the pump back off and disassembling the head assembly to blow out all of those bores? Was kind of wishing I did that.
Also, i noticed in my pics that the end plate has some scoring. I replaced the blades but not the plate. Assuming I’d just replace the end plate, transfer pump parts, maybe reg valve parts if it comes with that.
