Ford 4400 1969 gas - hard starting
Heet0006
Hi all. My tractor is finally running thanks to all of the help on here. I did a lot of upgrades this summer, plugs, wires, zenith carb, coil, and points. The tractor runs well when it runs. Maybe needs a tiny timing adjustment but she drives fine when she starts.
Thats the problem, when she starts. She is real hard starting. Any help you can provide in identifying possible culprits would be much appreciated.
Lucas
Verify that the choke cable is adjusted so as to fully close the choke valve.
Not an uncommon cause of hard cold starting for such models.
