Kick Back Ranch
1968 Ford 5000
Issue 1: PTO turns all the time now. Slower when not engaged and normal when engaged. If hook to the mower and I ground it out, the blades will stop the PTO from turning. Engaged it will stall out the tractor like it should. Filters have been changed, new Ford spec hydro oil, and new lift cover seals/pump seals. With the engine off I can spin the PTO shaft with little effort by hand (I cannot do this on my 1967 Ford 5000). When engaging the PTO it kicks it with seconds so I assume the control valve is good to go. Maybe the brake spring is shot? Or maybe the clutch pack is gone?
Issue 2: When I changed the hydro oil I noticed it was about 6 gallons overfilled. So on level ground I filled it to the correct level. The front end loader, MF 236, will function properly on level ground. But on any slight incline the loader won't lift. I pulled apart and cleaned the spool valve, hydro adapter block (new seals), and fixed one cylinder leak. After that, still no change. So I filled to 5 gallons over and problem has gone away. Stumped on this one????
Issue 3: Noticed a few hours after plowing, the lift arms when lifted high would leak down slowly about 2" and then correct itself. I'm assuming this is just old seals that are worn.
I guessing it's time for a lift cover rebuild, pto clutch pack, pto brake, and new hydro pump? Any tips or additional checks please let me know. Thanks, Daniel.
