Mandomaniac
Hey Folks,
Well, a good bit ago I was helped by a number of forum members with my 5000 PTO not completely disengaging. I popped the lid and replaced control valve (aftermarket AI brand...but still $$$), brake shoe, as well as found the cushioning spring disc in the PTO clutch was broken ....which I replaced as well.
Worked great after reassembly.....shaft completely came to a stop when lever disengaged, and smoothly turned when engaged.
Happy, happy, happy!
Operated correctly last hay season and did fine for first two fields this year. Then tractor seemed to bog down significantly when PTO turning round baler as bale grew. Managed to limp through baling the last of second field.....but noticed afterward the PTO shaft did not stop turning when lever disengaged. ARGGHHHHH!
Popped the lid today and found two of the internal spline friction discs in PTO clutch were warped. Ran into town, bought three new ones, replaced all 3 (external spline discs looked good), reassembled everything......BAD NEWS>>>
PTO shaft still turns (although slows somewhat) when lever disengaged.
What gives?????
Why would tractor bog down so much?
Why would friction discs warp?
One thing I can think of is clutch piston return spring might be weak? How can the clutch spring be checked?
Assuming the control valve I replaced is still good after only one year. The fact that it does seem to 'try' to disengage mean anything? Can valve be checked outside the tractor somehow? For that matter, any way to check it with lid popped? What would I need to do to run tractor with lid popped? Visions of fluid everywhere !!!
BTW, it does not act like brake is the issue (and brake was replaced last year). Can't stop it with levering wood against shaft.
Any thoughts on how to sort this out other than throwing expensive parts at it?
Popping the lid is not a terrible job...but a job none the less. Don't need to do it repeatedly! Sure would love to have some idea how to sort this out.
Any thoughts/advice would be appreciated. I need to hay!!!!!
What gives?????
