ford 5000 simms pump
The screw is on top of the pump in front of #1 injector line.
I wouldn't suggest turning it too much tho. The turbo itself, if it's sized correctly will give quite a boost.
Probably about 1/2 turn would put it in the 7000's territory and another turn should carry it over 100 horse.
If you don't have a dyno, BUY and INSTALL a pyrometer in the pipe close to the turbo. I'd not suggest running it much over 1000 F for any great length of time. That's as close an indication as any as to how much fuel it'll burn.
Rod
