Anonymous-0
need help ford 5000 diesel engine rpm drops when going down hill but runs fine with a load but today died while plowing changed fuel filters they where bad dirty started it up runs while setting at idle try to drive tractor and it still dies like the fuel was shut off any help would be great
I have a 1974 5000 row crop, it has done that before. You aren't getting fuel out of the tank for any number of reasons. It could have algae plugging the screen. If you have done as I have in the past and blown air back into the tank, you will indeed knock loose whatever is choking the fuel flow. BUT, in doing that, the screen will usually go away also.
I ended up getting a new shutoff valve that goes in the bottom of tank, pulled the old one out that was missing the screen and flushed the fuel tank as best I could by pouring kerosene in it with the valve removed. It brought a lot of crap with it, had to stick a fine wire up the hole a couple times to dislodge some big chunks. That was last spring, had no problems after that as long as I kept sediment bowl drained when it needed it. DOUG
Check your diesel, and your air cleaner.And ether could blow a head gasket.My 4000 had a blown head gasket when I got it.
Pull the fuel filter off again and see what kind of flow is coming into the filter. It should be a good steady stream. If it's not, head towards the tank and find out why not. Change the filter again too. It's cheap.
There could be crap floating around in the tank or there could be something blocking the screen in the shutoff valve.
If that doesn't turn anything up, drain the oil in the pump cambox and refill to the correct level. It could be dry causing some problems... or it could also be full of fuel and causing some problems. Go with that and see how far it gets you anyway...
Rod
