Carey Miller
Ford 5000 - Running rough and quits running. I posted last week about my 5000 running rough and then quiting. I have tried some of the suggestions and now have another one. I pulled the tank tap and everything looked fine. It appeared that the valve was not getting a good flow so I blew it out. I really thought this was going to be the problem.....but nope. I loosened the line to the bottom of the primer pump and had fuel. I loosened the top line and worked the lever and didn't get any fuel. I am guessing the primer diaphram has to be bad. Is removing/working on the pump and replacing the diaphram a shade tree mechanic type repair? The tractor is still in the woods and I can't get it to run long enough to get it home.
