Ford 601 pump leak
Steve Prince
I have a ford 601. WHen I finished raking the other day evry time I Lifted the rake the pump would leak out the vent port. When I lowered it it would quit. Now it leaks when ever I fire up the tractor. I talked to an old ford guy he thinks I blew the gasket. Any other Ideas.
It is the port that is on the return side of the pump. It just has a threaded plug in it. Initially it only leaked occasionally when it was hot. Then it leaked when ever I had the 3 point lifting. Now it has a slight leak when the tractor starts, but leaks like a sieve when I engage the 3 point lift. Tightening it does not work.
I realized I explained that poorly. Yes, there are two ports with plugs. The leak is coming from the one at the end plate closet to the bolts. The one in the pump cover.
pipe threads seal by thread deformation. The plug is soft cast iron. that means your plug likely has worn threads.
It's a 15 cent item... replace it!!!!!
soundguy
