Friend has a 755A TLB. He has had problems with the hydralic fluid overheating, and is unable to determine why. The hyd cooler is clean, and has a 10 deg delta when measured with heatgun. Transmission and engine coolant temperatures are normal. Removed hyd pump and inspected, was very clean and showed no wear or obvious problems.(He is a machinist/repair man) With tractor at hi idle, temp climbs above 165 deg quicker than normal, and he has yet to determine cause. Does this model have known cooling issues/problems, or has anyone experienced this problem before. Any hints/suggestions as to cause of this problem would be appreciated, as he is at wits end. Thanks
DSellers
DSellers
