Ford 801 steering
Clint94
I need to replace the bearing just below the steering wheel on the steering shaft on my 801 power master. How involved is this job and how much do I have to remove in order to get it done. By the way it has manual steering.
Thank you
First of all you should have a manual.
If you don't, buy the one at the link below.
You will need to remove the steering wheel
and enough of the sheet metal to get at the
steering column. You will likely need a
puller to get the steering wheel off.
Then you can remove the upper tube from the
steering box and renew that bearing.
You can also buy the bearing here.
It is all basic wrenching.
Repair manual
