B. B. Stanfield
My system does not seem to be charging. The generator is ginnin' and the regulator seems to work properly. I have yet to verify all settings, cut in and out points, etc. When it sits for a few days the battery is fully discharged and it's fairly new. I can charge the battery and the tractor will start and run fine. The meter simply bounces or shows a heavy charge for a couple of minutes then settles to 0.
A meter on the system shows the generator putting out the stated power, the voltage regulator is seeing the power at the terminal, but I'm not sure it's getting to the battery. The cables are proper guage, new and have good connections. The wiring harness is also new. The meter was wired backward by the local shop but is now fixed. I put a new battery on the system and it also starts the tractor fine, then will discharge in a few days. Can there be a "leak" in the electrical system and if so, where are likely places to look? (I suspect the regulator, generator, (rebuilt last year), and starter relay.)
Thanks guys,
Thanks guys,
