Ford 841 compression check MORE
grandpa Love
Compression check last week showed ,
front to back 5,120,115,120. So,
hood,gas tank and valve cover are off.
Doesn't appear to have a stuck valve.
Second valve back, on #1 cylinder, the
lifter is easy to spin with my fingers
until the spring starts to compress.
Very,very little up and down play. What
next? When I pulled all the plugs to do
compression check,all 4 plugs were
lightly sooty black. Tractor runs fine
some times, it's an occasional miss.
Leak down tester. You will put air pressure in spark plug hole. Listen for air coming out carb, exhaust or crankcase.
Only about $35 on amazon.
Lifter?? Or do you mean the valve adjuster?? As in the part you adjust to set how wide the tappet gap should be. I'd pull the push rod out and make sure it isn't bent then check how much it goes up and down if it isn't bent. If it still doesn't move as far as the others you may have a badly worn cam or the lifter which rides on the cam could be bad/broken
My response may be a little direct but if you want more than 5 psi of compression in that cylinder you have to pull the head. Well short of what old said to check the lift of the valves compared to others. One other thing to check is the tension of the valve springs. With that low of a reading it would likely need to be broke or deformed so you could see a problem. But to check them quickly position yourself so you can grab the head of a hammer, then with the end of the handle push down on the rocker arm over the valves firmly to open them slightly. Check the two valves on cylinder 2 first. Then check the ones on the problem cylinder. If the force to push the valves down are fairly even the springs are probably fine. If these things check out the only thing that will get you more compression in that cylinder is opening it up and fixing the problem.
Valve problems are usually consistent, not intermittent.
Check the valve clearance, not sure what it should be, usually in the .010 range.
Check the spring tension, compare it with the others. You should be able to compress the spring with heavy thumb pressure. If that one is noticeably easier to push, the spring is broken (visible) or lost it's tension. Easy fix.
Run the compression test again, just to say you did.
Start it up with the cover off, watch the valves move. Be sure all are moving the same amount. If one is barely moving you have a flat cam.
If the valve is not returning to the closed position every time, the valve is sticking open or the seat is loose and falling out, sometimes returning to it's place.
I doubt it is sticking as clean and rust free as it looks. If it is sticking, something is wrong, bent valve, loose guide, head needs to come off before a disaster occurs.
OK, Old and Steve have got the idea. Next test I would make is pull spark plugs, turn engine by hand, use fan and hold belt tite should work, and see if the adjuster end of the rocker your finger points to, moves up as much as the others. If not, probably got worn lobe. Looks like top end was getting enough oil. Before tearing engine apart, if that rocker does not have equal up/down travel, take push rod out and make sure it is good. If ok,wellll, then things get serious.
I talked to him on the phone and gave him a couple more ideas as to how to check things like putting ATF in the cylinder at the bottom of the compression stroke and then turning it by hand and see if he can get it past TDC and if he does where the ATF leaks out from. Either valve or even a blown head gasket or even broken rings
