Why not rebuild it or if your not able to do that there are people on this site that can/will do so also where you are located can make a difference as to who can do that for a good price and save shipping costis there a cheap replacement for my tsx 593 carb on my 55 ford 850 hard to justify a $400 carb on something I really use
If I can get a replacement under $ 100 would be better. by time I pay for kit, carb cleaner & the fact that I'm over 80 with bad eyesight. Haven't found any body close NE Pa. to do it. Even if I do, I'm sure it will be over $100 I see carb that look like it just wonder if someone used different carb & it workedWhy not rebuild it or if your not able to do that there are people on this site that can/will do so also where you are located can make a difference as to who can do that for a good price and save shipping cost
Well in the 40 plus years I've worked on tractors etc. I have yet to find a go replacement carb for many tractors and in most cases the carb comes from the land of almost right so they don't work well. Post this in the Ford forum down lower there are people there that can helpIf I can get a replacement under $ 100 would be better. by time I pay for kit, carb cleaner & the fact that I'm over 80 with bad eyesight. Haven't found any body close NE Pa. to do it. Even if I do, I'm sure it will be over $100 I see carb that look like it just wonder if someone used different carb & it worked
Thanks for help I'm new so don't know what or how post down lower Also is the tsx 593 the right carb for my 55 ford 850 . really close putting nuts on manifold Is slotted so wider would fitWell in the 40 plus years I've worked on tractors etc. I have yet to find a go replacement carb for many tractors and in most cases the carb comes from the land of almost right so they don't work well. Post this in the Ford forum down lower there are people there that can help
Very simple there are a lot of different forums and this is on the top of the page. Scroll down the ,ain page till you see the Ford ForumThanks for help I'm new so don't know what or how post down lower Also is the tsx 593 the right carb for my 55 ford 850 . really close putting nuts on manifold Is slotted so wider would fit
Some of the Amazon carbs work fine. Depends on the brand/seller. We have had good luck with dozens of them. BUT.....if your tractor is running terrible and you ain't sure its the carb a new carb won't be a magic fix. What are your symptoms?is there a cheap replacement for my tsx 593 carb on my 55 ford 850 hard to justify a $400 carb on something I really use
99 out of 100 carbs that my wife works on for us really just need a good cleaning, occasionally she needs a gasket to go between the halves. You can buy that from McDonald carb in GA. We always buy small engine carbs from Amazon,but try to rebuild old tractor carbs. We buy new ones if we buy a tractor with a missing or busted carbRuns well wasn't getting good flow of gas had to go back & clean tank & replace petcock now carb leaks cleaned needle valve & inside carb still leaks just thought quicker fix would be cheaper carb. I know on smaller engines like mowers & weed eaters it's just as cheap to get new replacement carb. thought i could go that route. most of the cheap. carbs on amazon are for 132 engine.
Yes, TSX 593 is the correct original carb for a 55 Ford 850.Thanks for help I'm new so don't know what or how post down lower Also is the tsx 593 the right carb for my 55 ford 850 . really close putting nuts on manifold Is slotted so wider would fit
I bought a cheap aftermarket carb from Amazon for my Farmall C. Works great after I made minor adjustments. $33.69is there a cheap replacement for my tsx 593 carb on my 55 ford 850 hard to justify a $400 carb on something I really use
