Dan Duebber
Ford 8 N Tractor is our everyday work tractor around the barn. I have had the same trouble for about two years now and I am now totally out of ideas on how to fix it. Tractor runs for 10 to 15 minutes.....then quits. It will restart immediately if I "kick start it" but will not restart using the starter motor. I have replaced the following: Ignition switch, volt. reg., wiring harness, both battery cables, starter and solenoid, all wires to the dist. + ignition wires, I also installed a rebuilt generator. I have replaced the points and condensor numerous times and the distributor is a factory replacement. Any suggestions would be greatly appreciated. I thought I finally had it by replacing so many new parts .........but it's doing the exact same thing again.
