just cut 3 acres today with 52 8n with a 5 foot brushhog no problems whatsoever,dont know about 6 footer,never had one
Russ.......the 26hp 8N and 5ft brushhogg are ideal combo. Remember to use an ORC (over running coupler) You will need to cut the sliding PTO shafts (2) shorter to fit. Mow with yer little "flush" handle under yer right kneesie in the UP (vertical) position. Horizontal is draught (plowing) control. Remember, yer hydraulic lift is PTO powered and so is yer mower blade. So when you "lift", yer mower blade must continue to spin. Just keep small dogs and children away from flinging rocks .......Dell
A 5 foot bush hog is the same width as your back wheels. A N can handle a 5 foot hog with no difficulty. Using a 5 foot will make it less likely you will skin trees and clip objects like fence posts when passing. An N will handle a 6 foot hog but you may not be able to take a full cut if the weeds have much height and the over lap of the back wheels can result in unintended damage. Consequently a 6 foot hog in most cases would not result in getting done any faster just more problems.
Ditto all that, plus, some folks recommend shortening your top link just a bit so the front edge of the mower is an inch or two lower than the back - that way you're not cutting the grass twice (the blades cut it once at the front, lower, part of the arc). And do use an ORC - it's a [i:06e6e1cf2d]very[/i:06e6e1cf2d] important safety device for the 8N anytime you have rotating mass connected to the PTO, and thus to the drivetrain.
If you're mowing on steep hillsides, you can reset your wheels in the "longer, lower, wider" position for better stability. My personal rule of thumb for hills is, "if it feels too steep, it probably is."
es
As Dell said, keep small dogs,kids and your truck (don't ask how I know) away from flying rocks.
My '51 handles my 5 ft. woods HSS60 mower with ease.
It will not operate a heavy duty 6 foot brush mower, period. A light duty 5 foot should be OK. Check the weight of the brush hog before you get yourself into this. Do you know how much weight an N will lift? Especially when it hangs way back there? If this brush hog weighs much more than 600 lbs, better look for a lighter hog or a heavier tractor. If it's a drawbar pull type, then all you have to consider is HP requirement to power the mower. That's a whole diffferent story. Nice level grass field? One thing. Heavy 5' tall swamp grass? With brush mixed in? Quite another story.
i run a 6 ft on my 51, and kinda wish i had a 5 ft, its not cause the tractor cant handle it, its when the grass gets either to tall or thick i have to shorten the pass or cut it taller and or mow it twice the time a 6 fter could save is wasted when you have to make the extra passes, all that said it will work just fine, but the 5 fter is a better match, (and as the others have said, an over ride coupler is a must)
Want to say thanks to all for the info. Did as you said and its working great. Again Thanks.
Now more help needed. To change to 12 Volt. Do I need to buy a kit or can I do it without the kit?
(quoted from post at 21:59:39 07/11/09) Want to say thanks to all for the info. Did as you said and its working great. Again Thanks.
Yes!!!
