Ford CM224 Vibration
Anonymous-0
Hello,
I have a CM 224 that will begin to vibrate when the machine is under a load as in going up a hill. The vibration occurs in either high or low range and with or with out the mower deck engaged. Any help would be appreciated.
Thanks,
Mark
Hydrostat? Check the oil level in the hydrostat. Going uphill you might be sucking air. Can ruin a pump real fast.
I had that same problem.Just ignored it and then one day BAM!Front u joint in the drive shaft came apart.If I remember it took around $150 and 2 hours to fix.Good luck.
Thanks to all, the front u-joint spline is worn where it attaches to the Hydro, oil level is ok. I have a new one on order.
Thanks again,
Mark
