Ford F150 - OT
Popcorn
Took delivery of a 2010 F150 in February. The following day the dealer replaced the steering rack, because it was impossible to keep between the lines on the road. That improved it some but it still wanders and Ford does not seem to be able to do anything about it. Anybody else have this problem or an idea how to correct it.
Have to agree. No way would I be happy with a new truck that wanders all over. now if it has a couple thousand miles on it and it's an F-150.... I'm told if an F-150 isn't wandering, it's likely not moving.
Take it back and demand it be corrected or replaced.
Should get a new one under the Lemon law. The man that replaced me bought a new Mercury SUV and had it back for numerous problems was the brakes and steering to name a few. He was given another new Mercury. Hal
PS: I have an old 1981 XR7 and never had any problems.
Try swapping the tires front to back and see it it helps? Maybe ball joints? Never had/heard of a Ford F150 do that.
Hurst
If ford don't give you satisfaction and your stuck with the truck(hope that won't be the case)A diffrent style of tire can make a huge difrence and it probably needs a front end alignment after replacing the rack.They might not have dun it because of ignorence.
Popcorn, If they are not able to fix it, do check the lemon laws in your state. I have a lemon law book in front of me. It looks like every state has different requirements. Some states have a time frame built into them. Some have milage requirements built into them.
My 2 cents. That is the very reason a person could'nt run fast enough to give me a Ford.I've had 4 new fords over the years,no more.And the springs are about like jello.My daughter has a bronco,its the worst driving of all. I would not drive it 50 miles if she would give it to me.She is the only one that will drive it.She has had the front end reworked twice at the ford dealership.At about 2 grand a lick.But she loves the d**n thing.
come on guys iv"e had fords for years and models from 72 to 08 f150" and f250"s every one has driven great. there is definitly something wrong with this 2010 truck and a good dealer can fix it. i"m just sorry to here of your problem, but like other"s said stay at them and make them fix it or get another one. i take it you bought it new, probably an easy fix if the right guy looks at it. good luck
It sounds like either they left some parts off or this frame was damaged and they used it anyway.
Before you put any more miles on it, go get the process started under Lemon Laws to have it replaced free of charge.
Did you not test drive it first? Im just not understanding why if you did test drive it, you still bought it.
Sounds like alignment or more likely tires.
I had an '89 F250 supercab that I put 2 new Goodyear tires on the BACK. Made the thing almost impossible to drive. It wanted to wander all over the place and lane changes were almost uncontrolable. Acted like both rear tires were going down but they were inflated properly. Shortly after that I had 2 new Michelins put on the back and moved the Goodyears to the front. Drove great!
Check front wheel bearing adjustment. Sons dad had one with no cotter pins. Almost killed him. True story. Idler arm could cause a lot of trouble too.
