Ford F350 Keyless Entry
Tweeter
Had to get a replacement keyless entry for my 1995 Ford F350 pickup and cannot figure out how to set it. Anyone know what I have to do? The truck has the factory keyless entry option.
is it possible that the settings are in the trucks computer and not the unit on the door? just a thought.
I found this at the site listed below
I have a 94 F-150 with factory keyless module mid under the dash. There is an open end 2-pin connector close to the control module under the dash. You have to shorten that pins, then turn ignition On, then press any key on the remote, then turn ignition Off, remove the short link and it is done. You may try that if yours also has such 2-pin connector.
Looks like a good place to search
On my Chevy Trailblazer, they sent detailed directions on how to 'program' the key 'fob' to the vehicle, it worked out real well. Checked for my daughters Grand Am, and the same place (on the web) says it would need a locksmith or dealer to program that one. Sorry, no 'for sure' answer, just some things to consider. Try google with that specific question. I have found all sorts of info 'hiding' that way. Greg
Are you asking about the fob that goes on your key ring or the touchpad that you push a combination to enter? On the fobs, you gather all the fobs that you are going to have for the truck and have them inside the vehicle with you. Put the key into the switch and turn completely on and completely off (i believe) 7 times. At that time your doors will lock and unlock signaling that you have done the key thing right. Take each fob and push the lock button and then unlock button. Your vehicle is then programmed to accept the signal from those fobs. Sounds whacky, but that is what the owner's manual says to do.
