Ford Jubilee 3 point doesn't move
Uppercut11
I was given a ford jubilee that hadn't run in over 16 years. Through lots of work over the last couple of months I got it running. The problem now is that whether the selector for the 3 point is in manual or draft mode, the 3 point doesn't move. It has the original vane pump (see picture).
My overall question is what the potential problems are and how I diagnose and fix them.
It seems like the first thing to check is the prime on the pump, but I am not sure how to check that. Should I remove the two bolts from the pump that hold the smaller (high pressure) hydraulic line and start the tractor to see if oil comes out of this hole? Where it is on the bottom of the pump I am wondering if oil will just run out if I remove the line.
The adjustable flow control on the end of the pump was turned out quite a ways and I turned it back in to make it hand tight thinking that might help, but there was no change. How should this be adjusted?
Any help is greatly appreciated!
You should get a service manual or I&T FO-19 but in the meantime here is an
excerpt telling how to check for prime.
<IMG SRC =https://i.postimg.cc/ZYGk3v1Y/NAA-Vane-Pump-Prime.jpg>
Thanks. I fired it up today and brought it to low idle and was going to put some compressed air into the dipstick hole to prime the pump and it just started working. Guessing that it got prime on its own. Either way I will take the good luck.
