Ford LGT 125
Anonymous-0
I have problems with my tractor. it sat along time without being started but we got it running for about 30 minutes before it shut off. i was told it had bad wires and it need a wiring harness, it was sent to a mechanic he also told me it was the wiring harness. it started and ran before now after i reconnected the wires replaced the starter and the solenoid it only turns over if you hit the battery and starter cable the ignition is hooked up and missing a wire ims that the problem?
