Ford loader tractor
grandpa Love
Bought this a while ago. Got it running poorly. Water pump was shot. Manifold had holes rusted through, radiator was leaking. Got parts from Tracy Brown last week. Got it all back together today. Nice running tractor. Unfortunately when the clutch is out it makes a terrible noise, press clutch and it get quite.... Throw out bearing??
Throw out bearing rattling on the shaft or maybe transmission input shaft bearing. Does the noise go away with slight pressure on the clutch or does it have to be fully pressed?
Nice Old Ford.
If your saying when you let off the clutch pedal you have noise
It's most likely a bearing in the transmission.
If you have noise when you push the pedal then it's throw out or pilot bearing.
Tom
Adding to it..... Once you get rolling you can take it out of gear and it still makes the same noise. Clutch in or out.....
Sounds like the input shaft bearing, possibly the counter shaft bearings or the input gear that turns the counter shaft.
Sitting in neutral, engine running, clutch engaged, that's all that is turning in the transmission.
Some input shafts can be removed from the front without a complete tear down, not sure about that one.
Have you checked the oil in the transmission? Probably too late if it's grinding, but if it's really low, might top it up with something, even if it's used oil, it will probably be drained back out anyway.
Just had my transmission rebuilt on my 961 diesel. Input shaft stripped out. Thankfully a friend had a good one and I had a spare 5 speed for all the rest of the parts needed. Was expensive as I had a proper mechanic do the work. If the engine hadnt been rebuilt 3 years ago I would have questioned doing it.
Vito
IF oil level is low and it has sett for an extended period it could be just dry and needs oil. If through out bearing just grease it and see if it changes any. If no to both then probably deeper than the clutch and a bearing.
