Ford tractor indentify
Silkwood38
Hello, I have a Ford tractor, trying to find out info on my ford tractor not much help on the internet can someone help me out? #’s 2G19,B913667*,2F26C,C7018 casting numbers on bell housing. The water pump is shot and I need to order one. Can anyone help?
Post some photos and we'll identify it.
B913667 is the serial number, B means made at the Basildon England Ford plant for domestic (as opposed to export) use. 2G19 is a date code for July 19, 1972, probably final assembly date. 2F26C is another date code for June 26 1972 afternoon shift, probably transmission assembly date. C7018 looks like a model code but doesn't make sense
It should be 6 characters not 5. C would indicate a 3000-series tractor but 7 in the second digit doesn't compute. Try looking for a sticker under the hood, the codes should be repeated there.
C7018 is the code numbers for the transmission usually located on the left side
The model code is missing but I have seen European models without that code
Being a 72 model all 3 and 4 cylinder models share the same water pumps, there’s either the most common single grove pulley or dual grove
Thank you for the info. I will be looking under the hood for these numbers, this will help me in ordering the correct water pump.
