freeing up stuck engine
Fallon
Got a cat 10. Engine is stuck. Want to try to free it up pulling plugs and soaking it. What are some of the best fluids to use.
Fallon, I have used 50% AFT and Acitone. Or ATF with PB. If it is dry stuck it will work in a week or two.
If it is water damaged It's more difficult. Most times you have to pull head and pan remove rod caps. Than smack the pistons with a block of wood. You should pull pistons and clean rings anyway. oldiron29
(quoted from post at 09:42:46 12/28/10) Kroil from Kano Labs
Only available mail order, google it.
Kroil is available in most gun shops these days, since people found it's a great gun cleaner. It's one of the best products of it's type out there.
(quoted from post at 17:00:40 12/28/10)
In our area some HVAC and industrial supply houses sell it also. It is tough to beat the mail order when they do the 2 for 1 trial deals!!!
(quoted from post at 18:14:50 12/29/10) i read one time to use orange soda pop not sure if it works but may be worth a try
Coke will really do a number on rust as well.
The most popular I have read on the forum are ATF/HyTran, diesel fuel, or your _____ penetrating oil.
Anything but WD-40. It's lubricating/penetrant properties are so far down the list, they're almost not worth mentioning.
This is a Catepillar TEN:
It's a 10HP crawler tractor.
Whatever you use, TIME is the most effective tool.
Don't expect miracles; you're not going to shoot some PB Blaster in the spark plug holes, huff on the crank, and break the engine loose in 5 minutes.
Also, don't hook an 806 to the front and try to break the engine loose after it's been soaking for a month... I speak from experience.
