freeze plug
Anonymous-0
My dad has a 1960 Mod. 600-601 ford tractor. Is there a freeze plug located at the rear of the block at about the 12 O:clock position. Any information is appreciated. Thanks
Roger
Ford hasn't changed a bit. Had to replace the soft plug on the back of the head in #1 son's F-150 with the 300-6 engine. After a lot of head scritchin', I bored a hole in the firewall with a hole saw and replaced the plug. Was a lot quicker and easier than pulling than engine.
Does this help you? I didn't think so.
At onetime there were neophrene freeze plugs available that you could tighten with a wrench in hard to get places. They may still be available. Antifreeze will lose its rust inhibitor and then start to work on the metal. I change the antifreeze after 2 years use. It will
cause the heater core on a truck or car to leak.
I have a 1981 Mercury Cougar and its a major job to replace the heater core in it. Need to pull the dash to gain access. Hal
