thumbanger
Does anyone know the freeze plug size in Super C 123 engine. Thanks for any help
My experience is with A and B tractors, but your 140 uses a newer version of the C-113 engine. Let's assume there has not been many changes in block design. Therefore, I will state that I am not aware of an expansion plug behind the alternator. Unfortunately, the bottom of the water jacket and front left corner of the block seem to be favorite locations of freeze cracks in these blocks. Hopefully, this is not the case with your tractor, but you must recognize the possibility.I seem to have water coming out of my 1971 farmall 140 just behind the alternator bracket. Is there an expansion plug somewhere around that? Would be front of the engine, but Drivers side per say.
lbp,
Call 'em what you want, the official name in the IH C-123 partsbook is "expansion plug".
Oh man...I bet it cracked... It had tiny bit of a leak at the bottom elbow and I never took the time to remove the radiator and fix the leak at the rubber hose. So in short, I would only use it 3-4 times a year to work my 1/4 acre garden. Hipping and then cultivating maybe 3 times before everything got too big for the tractor.... anyways all the coolant leaked out the first time it developed the leak, so I would just fill it with water and it would run the full time with water in it. then it would stay parked for 6 months until the next season. However we had a fluke freeze 2 years ago and the leak has gotten substantially worse. I pulled the radiator and fixed the hose but still leaking bad and now you have helped me come to the realization the block probably cracked because there was a pocket of water from before the freeze that just sat in there and then froze hard enough to crack the block.
For the record I live 15 miles from the coast near Houston. Hard freezes like we got are extremely rare and I know I should never never never put water in the coolant system, but i'm sure someone is going to try and educate me further lol.
So....it was leaking out of the bottom hose? If it was sitting for several months before it froze I would believe most of the water was drained out. And if there was some water left it would have plenty of room to expand when it froze. Don't panic until you remove the alternator and clean the area where you can inspect it properly..... If it's a water jacket crack in the block, remember it's a very,very low water pressure system. V groove the crack with a Dremel tool, clean it good and jb weld it.....Oh man...I bet it cracked... It had tiny bit of a leak at the bottom elbow and I never took the time to remove the radiator and fix the leak at the rubber hose. So in short, I would only use it 3-4 times a year to work my 1/4 acre garden. Hipping and then cultivating maybe 3 times before everything got too big for the tractor.... anyways all the coolant leaked out the first time it developed the leak, so I would just fill it with water and it would run the full time with water in it. then it would stay parked for 6 months until the next season. However we had a fluke freeze 2 years ago and the leak has gotten substantially worse. I pulled the radiator and fixed the hose but still leaking bad and now you have helped me come to the realization the block probably cracked because there was a pocket of water from before the freeze that just sat in there and then froze hard enough to crack the block.
It is worth note that the front of the block of the C-123 was redesigned for the 140/240 to use a more modern style water pump. Consequently, a drain plug was added to the block. If only the radiator is drained, the block will still be holding water. I don't believe there were any changes in the expansion plugs at that time (cold be wrong on that).My experience is with A and B tractors, but your 140 uses a newer version of the C-113 engine. Let's assume there has not been many changes in block design. Therefore, I will state that I am not aware of an expansion plug behind the alternator. Unfortunately, the bottom of the water jacket and front left corner of the block seem to be favorite locations of freeze cracks in these blocks. Hopefully, this is not the case with your tractor, but you must recognize the possibility.
Good luck.
Farmalldan
In my opinion that little starting motor being made out of fairly heavy cast parts was a fairly good heat sink in itself. I doubt in the run time that it raised the coolant temperature much more than adding a couple luke warm gallons of water to the cooling system. Sure something is better than nothing. Next to the fact that the pony motor could crank it continually with no worries, the greatest positive towards starting the diesel was the fact that it’s exhaust ran through a pipe in the intake manifold to heat the air coming in the engine. Very helpful towards starting a cold diesel engine.Got experience with the water deal on the Cat dad always wanted wtar in it so you could pour hot water in it in cold weather to warm the engine from the inside some for eaier starting. then drain when done with the days use. Well That is what happened . It came on the yard with antifreeze in it and it had to be drained .Though it started just fine as it was with the little engine heating the water/antifreeze as it ran to start the big diesel engine.
