Front Mount plow
I just purchased a front mounted plow and frame and have it mounted. My question is first, how high should the blade lift off the ground when lifted, and second, I have it mounted like I believe it should be but cannot get it to come up more then about an inch. I have the cables as tight as i can get them. Any tricks anyone has used to get it to come up higher>
I have the same problem with mine. The cable clamps get in the way at the pulleys and no go.I'll be watching for some answers as other members check in.
If you could I would like to see more of a picture of the plow. This is new to me. Why would someone want the plow mounted in the front? Seems like in the rear is the way to go.
Curious
FD,
You can push a lot more snow going forward than in reverse.
With a back blade on you are either pulling the snow forward into your tires or pushing the snow backwards which the 3 point really isn't designed for.
Front mounted snow plow - properly set up with rear ballast and tire chains make an awsome little snowmover out of an N.
Is that an Arps Frame and Dearborn plow. Looks like it to me and that's what I have. They don't lift very far, maybe 3-4 inches or so. If it only going up 1 inch, look for what stopping it.
I have a blade that looks exactly like the one pictured but the frame is different. My frame is made to fit around the undercarriage of my 2N and is 2 inch heavy duty pipe. I can see where your set up will not lift very high. In Minnesota a one inch lift would not be very effective when we have a typical snow year.
I don"t have that frame but you should be able to lift high enough for those vertical plates to hit the underside of your axles. With mine if I touch the axle the plow blade will be about six inches off the ground.
<a href="http://s135.photobucket.com/albums/q121/JackL_06/?action=view&current=P2140104.jpg" target="_blank">
P2140104.jpg" border="0" alt="Photobucket
</a>
Jack
I have the same setup and by setting the plow down and pulling the cables on the rear pulleys as tight as I could get it, have managed to only get about two inches clearance when lifted. It is possible that moving the bar that fits across the 3-point arms back further would give you a longer throw (pull), but you would have to find a way to fasten the bar in place. If you find a solution to getting the blade higher, please put it on here.
Trucker---this is a Dearborn setup...I get 8" of lift off it. Had to put a hyd. jack under the front of the frame, jack it up tight to the tractor and then tighten cables as tight as possible.
Note the differences in front mounting brackets/cable, etc..I have just enough clearance to push snow over a city curb, up onto the turf....otherwise this setup would not be very useful.
Tim
A previous owner had put extensions on my lift bars and that worked fine. I don"t use the three point any longer as my 671 is 12v so I use a winch.
<a href="http://s135.photobucket.com/albums/q121/JackL_06/?action=view&current=Snowplow.jpg" target="_blank">
Snowplow.jpg" border="0" alt="Photobucket
</a>
Jack
Thanks for all the suggestions. I'll have to take a look at it more today and see what I can do to get it to raise higher. It could very well be that the clamps on the rear of the cable slipped.
