fuel injection pump
I have a Deutz tractor that is a D4006 and is a 3 cylinder. My old fuel injection pump went out. I have a new one I just put on. The guestion is the old pump had a seal at the shaft to keep the oil in, I'm guessing. The new one does not, so is the oil in the motor going to run in around the shaft and oil the pump? Also the other end of the pump had a plug at the end and a big hole at the top to add oil and to drain the access oil and fuel. The new one has the big hole at the top but does not have the drain hole at the bottom. I would appreciate any help. Thanks
The new pump is to be pressure fed. You have to add an oil hose from the engine galley to the new pump. There is a kit to change to the pressure fed pump.
Robert,
It sounds as if you received a pump for the 913 engine family instead of the 912. The 913 injection-pumps lubricate off of the engine's oil system. The 912's actually had their own reservoir.
