Fuel Problems
AcFarmr89
Alright, Our 190XT series 3 is having fuel issues. Tank is clean, Fuel lines are clean, New Fuel filter, And injectors are giving furl to the engine. But, Will only run for 30 seconds. Acts like its not getting Fuel. I'm thinking time for new Fuel injection Pump. What do you think the problem is?
Take the return line fitting off the top of the fuel pump. Look for little black particles in the fuel. The Roosa Master pump is known for the inertial ring in the governor deteriating and the pieces plug the return line and hydro lock the pump. If that's what you find, it's time for a rebuild.
Is there a check valve where the return line connects to pump. It has a glass ball in it. If leaking or missing ball maybe your problem.
