Fuel Saving Tips
Anonymous-0
Aside from effective driving habits, what would you say are some practical, perhaps lesser known, tips to improved fuel economy with gas powered cars and trucks?
I have some ideas, but would enjoy hearing your responses.
Thank you,
Glenn F.
Hello Glenn F
Tire pressure 2 to 4 lb. higher then standard on door panel specs.
It does not affect the tires. You will have to do the math before and after to see the difference.
It is something easy to try, works for me.
Guido.
Air dam good for 1 or 2 mpg. Check that everything works. A non functioning torque converter clutch can cost 4 mpg.
"They say" checking tire pressures regularily would save the country thousands of bbls of oil.
Could never understand why leaving a red light was like a drag race,even in a 25 zone.
Same with leaving work.Its like a mowed anthill.You're done for the day,sit a minute or two and let the lot clear,then proceed at a mellow pace.5 min longer gettin home just don't matter vs the "rush".
Keep you modern vehicle tuned to specs and leave it at that unless you do heavy towing or such.The mfgs spend millions getting the best generic mileage/performance combos outta every vehicle..Joe Shadetree prolly ain't gonna be able to outguess em except on "special" apps.Hype is just hype,heck if I ran the filters,pipes,chip and oils&gimmicks that were hyped the most,my V8 4x4 should get 55-70mpg....ain't gonna happen.I can buy a lotta gas fer that couple thousand in"fixes".
You know when gas is high when you trade your truck in and the sales person asks how much gas is in it before he gives you a value on it
Avoid haulin around a lot of extra weight. Don,t use your vehicle for storage. My crossbox tool box weighed nearly 500 lb. with tools that I seldom use. Now there is about 100 lb. that I just got to tote around.
read ''ease on down the road'' in april readers digest. practical?-- not for me, but this guy uses every trick there is. subtitle reads: ' how far can a gallon of gas go?' 'how does 150 miles sound?'
Hi Glenn,
I read an article like the one that dieselpaul saw in the Readers' Digest. What it convinced me of the most was that nobody can do math anymore, and nobody writing articles bothers to take the time to check their sources. For example, the writer claimed that this tip alone would cut your gas usage by 19%: In a parking lot, always find a spot where you can pull through so that you're facing out and can leave without having to back up first. The 19% claim is pure horsefeathers, but I do it anyway because it wraps around another habit I've had for years. I always back into a space in a parking lot so that I can drive out forward because most parking lot accidents happen when people are backing out to leave. There's little potential interference when you're backing into a space, and you can see what's going on a whole lot better if you're going forward when you're leaving. Now, instead of backing into the closest space I can find, I park a little farther away where I can drive through to be facing out.
My other gas saving suggestion is to put larger tires on your back wheels so that most of your driving is downhill. I think I stole that from someone else on this forum, and I've used it here before, so I suppose it's about time to drop it.
All the best, Stan
Park your truck and do your running around in a little station wagon. In the old days we called them 'winter beaters' even if we drove them all year...
My '82 Civic SW gets 32+ mpg and will carry half a ton of beans or feed if you have a lick of sense. Carrying anything over 10'long means that the tail gate needs to be open a little. Empty, it is a lot more fun to drive than my 1 ton.
Greg
I don't have a wagon but I can get a whole bunch of grass seed or tobacco chemical in cavaler work car. Gets a little over 30mpg and is easier to get around town in when going for a fuel filter or a baler bearing.
The co-op is between work and home and the NH dealer is only 6 miles out of the way from work to home where it is about 20 miles from home. If I don't need something right now I make a list and stop on my way home in the mornings.
Another thing is I have gotten a 300 gallon gas tank for the house. Used to just have farm deisiel. I figured up how many times I was drive'n to the nearest gas station to get gas for the lawn mower, four wheeler, or my little gas tractor and it was aobut one trip a week. I try to get 150 or so gallons on a down swing in prices and have gas at the house to run the small stuff.
Dave
I found by putting on a electric fan and larger exhaust pipe 2.5" vs 2" increased my mileage by slightly more than 2.5 mpg. Plus its has more power and is less noisy (fan)
The Snake Oil dealers are at it again..On page 41 of Popular Mechanics (march 2008 issue) the is a full page ad for getting 121mpg and it will only cost you $1000. see www.picctv.com for details
Overload smaller pickups. We run a lot of weight in ford and chevy compact pickups with 4 cylinders.
Pile 4-5 people in a Geo Metro or a VW rabbit. Riding around in your one ton truck is getting to the point of being absolutely ridiculous.
All the V8's are gone from most of my family. The occasional tractor haul is done by the old one ton farm truck.
We're going green - for the sake of saving money.
Slow down.Running at 55 on the interstate I see pick ups pulling horse trailers passing me and pulling away fast.Ton dual wheel trucks going 75 mph suck up the gas.My 4WD got 19.3 mpg in a 100 mile trip.351 v8 auto trans mission with OD.4Wd trucks seem to be under constant attack by people who dont use one.My truck shifts into OD at 45mph so I run 45 to 50 mph.Never have been a fast driver as 45 was the speed limit on most all roads when I started driving.Cop clocked a hybrid Toyota doing 85 on the interstate.State Rep plates on it.I dont use my truck often but when I need to haul 1000 lb of lumber,fertilizer or fire wood I need a truck not a feather hauler.
Own multiple vehicles. Governments are giving us lip service with their desire for higher mpg. States could mandate insurance and registration for multiple vehicles for the price of a single vehicle. We would use the vehicle appropriate for the task.. Once every two months we need the 12 mpg truck so it gets insurance and the 35 mpg car sits.
Do a search for hypermilers, they just try to squeeze crazy gas mileage out of regular cars using driving technique. Some getting 80 mpg out of civics etc.
I tried some of their tips half assed and got an extra 80 km (50 miles) out of my tank driving to work.
Use a bicycle when you can. My Dad had several parked around. Sometimes he'd get them all in the same place and one of us boys would have to retrieve one. We had a couple of smaller farms within a half mile and he'd often peddle there to check stuff rather than climb into a car - unless it was one of ours (kids) especially just worshed....
I run errands in a little Dodge Shadow with over 180,000 mi. manual shift. When I'm in the country and coming up to an intersection where I have to turn or stop, I check the rear view mirror and if no one's close I put it out of gear and coast the last half mile or more. Saves brakes too. Only one brake job so far.
I've done the same but I read when decelerating a standard trans fuel is completely shut off. You using fuel to idle.
I keep asking my insurance office why a driver can't be insured for PL&PD rather than insuring each vehicle. Then each vehicle could have whatever collision, comp, or other insurance or none. They just laugh. The way it is now, they collect money for state required PL&PD on every vehicle.
And in California, the company is required to report to the state if your insurance is cancelled; then the state suspends your registration. Proof of insurance and a $14 bill will get it reinstated.
I bought, registered and insured a used pickup the same day, but two weeks later the registration was suspended because the insurance company took too long to notify the DMV that I was insured.
