G almost done
The pic I mentioned yesterday, I tried to put two on im not completely sure if it has worked. This is my 1948 G Deere I am setting up for pulling, its almost ready to go! Just awaiting the plates to put the 9 bolts on, then im bringing it up to the shop to run the dual exhaust theres only the single pipe in the picture. Also needs the weight brackets, spent a bit of money on this..... The only issue i had going through it was a leak in the big nut carb due to a torn gasket i hadn't noticed.
It should be done by next weekend, the first pull i know of around here is the Luck tractor pull i will be going to that July 20th i believe it is unless i can find something sooner! I'm pretty excited are you heading out to luck?
uh ohhh, looks like i got some new competition...lol, there is a pull in River Falls on May 16th, starts at 1pm i believe. adress is W10175 690TH AVE RIVER FALLS WI. Thats all the info i have as of now. last year lightest class was 6,000lbs, but that could of changed. Best of Luck!
Carl
Haha im running 18.4-38's on there rear, i havent dynoed it yet and have not a clue as to the power! Although i think she will pull in 3rd unless i find out she's capable of otherwise!
Thanks for the info carl! Shes weighted in at around 5000 pounds so if i head down there i better make sure to bring a bit of weights to be safe! Is it mostly farm stock do you know or are there open and hobbys runnin?
