coonie minnie
So I have my G clutch apart again.
A refresher... it slowly developed a scenario where the clutch would either be too tight to stop the pulley, or too loose to pull any kind of load.
I've installed new facings, bolts, dogs, toggles. After reassembling, it seemed the driver casting was on too far. I replaced it with a different one. When really tight, it is approximately 1/4 inch proud of the crank shaft end. Too far??
But I've also noticed the following- when I have the pulley sitting upright on my bench, if I manually activate the actuating sleeve, it seems like I will only get perhaps 1/8 of an inch of movement of the bolts in and out. I'm thinking it should be more, and I'm wondering if my sleeve is worn enough in the holes for the toggles (dog bones) that there is too much lost motion? Also, the holes for the pins for the dogs are worn, and there is some slop there as well. Is it possible that all of that wear -a little here, a little there- has meant that I've lost a lot of engagement motion???
Any thoughts are appreciated.
