My 1950 "G" has developed a knock. I've noticed it off and on for a little while, but today I plowed a little and it's definitly gotten worse. The only time I don't notice it is when the engine is at a slow idle. If I listen with a piece of hose, the knock is very obvious when you listen at the center of the flywheel. You don't hear it much at all if you listen in the crankcase breather ( meaning I assume it's not the rods). It almost seems like there's someone tapping under the operator platform with a ball peen hammer.
I've replaced the flywheel bolts, thinking maybe it was a loose flywheel. That hasn't seemed to help. Could it be in the clutch? Any other ideas? Am I going to have to mentally prepare myself to pull the crank this winter, because if thats the case I better start on that now, ha. Thanks.
