G1000 wiring
I don't suppose anyone has a wiring diagram for this beast they would be willing to scan or fax to me? Or point me to a site where I could print one/
Curt
What area do you need? Just built a new wiring harness for Jet3 Industrial. Should be same. I used 670S shematic.
There's a 4 bay connector to the rear of the machine. I have it figured out where they all go but one. A black wire disappears under the 3 pt. lift cylinder and the crud is so thick and heavy I can't quite figure just where it was headed. It may have just gone to an auxiliary jack but I'd feel better knowing.
Thanks,
Curt
(quoted from post at 16:51:36 04/17/20) I don't suppose anyone has a wiring diagram for this beast they would be willing to scan or fax to me? Or point me to a site where I could print one/ Is yours a G1000 or a G1000 Vista? I believe the wiring is the same. I have the G100 Vista repair manual for mine, and it has possible several pages and part numbers and partial schematic for the instrument panel and a good one for the lights on the tractor. I have a starter to put in my 1086, but could perhaps fax the pages to you this evening if your are interested. Other wise, you could call the Floyd County Museum in Charles City Ia. and they might have a wiring schematic to send you. (they are the depository for MM and Oliver materials) Their number is: 641-228-1099.
Wire would either go to the implement socket or transmission line pump oil pressure sender for the idiot light on the dash if it has one like the G900's.
