Galvanized Pipe Connector
Hello all. My hot water line is leaking under the slab. House was built probably late 60's. I am trying to run pex overhead. Tore out paneled wall on back side of shower. 1/2" galvanized coming up through slab to mixing valve I can't get to. Was thinking of cutting pipe and trying to thread with a ratcheting or powered pipe threader. Don't have much room. Any ideas or recommendations? TIA!
If I understand you, you want to run new pex above the slab. Good idea but I would get rid of all the pipe at the same time. you might be able to clamp something on there but I wouldn't. Every job I have done or redone we installed access panels to remove all taps at a later date. As many taps as I have replaced in my life I can not believe anyone would build without it. If I can use a tap 10 years before it starts to leak I think I'm lucky.
This is a good reason to do a reno project. Think it through and even run a temp hose on the floor for a week or 2 while you decide how much reno you want to do. I am cheap and don't have much money to spend, but I do have time on my side. renos do not have to cost a lot of money. Of course I don't need it fancy when finished either.
Andy griffith told aunt bee to “call the man”. Sometimes you just have to bite the bullet and write the check!!
Two possibilities, after cutting the pipe off
#1 find a good welder/boilermaker. I've worked with some who could weld a fitting on to those pipes
#2 find a good sprinkler fitter, they will know the right Victaulic fitting to solve your problem. I'm not sure about code if burying the Victaulic fitting in the wall, but that's a separate issue
When you say you don't have access to the wall behind your shower, I assure there's something immovable in the way, such as a stairway or furnace. You may need to be creative. I recently had to replace a shower valve that had a vanity behind it. I found that if I took the drawers out of the vanity I could cut a hole into the wall and access the shower valve.
What about tearing out the shower wall? If it's just a fiberglass insert, those are pretty cheap to replace. Or if it's tile and is original, it's probably overdue for replacement; back in the day they just stuck tiles directly to non-water resistant drywall with mastic. It might be a good time to tear it all out and replace with better materials such as cement backer board.
