Gapless rings
Anonymous-0
What's the general opinion on gapless rings? Are they worth the extra money? Top ring, middle ring or both? I'm running higher RPM's, overlapping cam and using steel sleeves. I've used them on automotive engines and picked up a good seal and a little quicker time in the 1/4 mile.
Didn't have a lot of luck with low tension rings. Gas ported pistons worked as did flame cutting the piston domes.
If you have 1/4" rings, you can change the 2nd ring to 2- 1/8" rings..that gives you an overlap that makes it gap-less..
Seems it is not recommended for the "top ring" as it takes more abuse from carbon, heat etc. and might be somewhat less stable than the 1/4" width at the top position..
binderdog i see that gapless rings require some gap verry small compared to the ring gap of file fit rings that require a gap of 16 to 18 thousandths depending on bore size. I guess im old fashion in some areas as bad as that sounds to me .
