timberwolves
After brush hoggig with my MF-65 for a hour or so, when I checked the level of gas in the tank it let out alot of air. Could my gas cap be bad and cousing pressure to build up in the tank ? Doe the cap have to be vented. If so any ideas on what cap to use ? Thank you John
Yes, gas cap has to be vented. I believe each tractor company has a replacement program with free, updated gas caps. Do a search of this site to learn the particulars and other peoples' experiences with the program.
Let out a lot of air? Do not see how you can build up pressure?
I'd say you vent may be partially blocked. And you had a vacuum building. If totally blocked the fuel use will create a vacuum until fuel no longer flows and the engine stops.
Jeff
OK so it built up vacuum, not air pressure. What could cause vacuum to build up. The gas cap looks kind of new but I dont know. I dont see a vent hole on it either. Any ideas?
Since it is a gravety fed fuel system as the fuel runs out, if it is not displaced by more air the pressure drops until the fuel no longer flows...
yes you will build pressure in the fuel tank as your tank and fuel heat up it will build pressure if it is not vented seen a tank on a IH M split the tank setting with a full tank of fuel in 100 deg. sun. with a none vented cap
You say the gas cap looks kind of new. I assume that means you didn't buy it but whoever did, apparently didn't know any better and bought a car gas cap that fit the tractor. Cars have had non-vented caps for years because they vent through the charcoal cannister. When a non-vented cap is put on a tractor, the heated fuel often expands faster than the tractor uses it, with the possibility of blowing off a gas line or bursting a tank. The gasoline spraying over hot parts, ignition parts, and the driver.....well, you get the idea. I've even had a parts man at the tractor dealer's counter try to sell me a non-vented (locking) gas cap. So few people know the idiosyncrasies of tractors these days that the owner has to educate himself/herself to avoid learning the hard way.
